Old 01-22-2022, 08:14 AM
msinc msinc is offline
Cobra Make, Engine: Superformance aluminum 427FE
Originally Posted by Blas View Post
Feel free to call me. If you use the standard shoulder belt setup for an SPF you need to get a “Y” type harness that attached it to the frame using the bracket I sent you a photo of. Your other option is adding the crossbar on the hoop and attaching the belts individually to the eyelets on the crossbar I sent you a photo of that from my car. I have also seen individual belts looped over the crossbar. But I’m not sure that last option is as safe. I sent the service bulletin for the proper install too. Either way, the connection point must be at the correct height relative to your shoulders to prevent spine compression in the event of a shunt. See my photo gallery for photos.
Thanks again for your Wiring Diagram purchase too….
Blas
Blas, thanks and I understand and agree with everything you are saying sir!!! My question is what brand and where is the best place to get them???
