Old 01-30-2022, 04:26 PM
mavgarb302 mavgarb302 is offline
Cobra Make, Engine: Backdraft blk edition 427r build #2297 grigo telesto color
Originally Posted by Tommy View Post
I've had clutches in two different cars act that way. The first had a hydraulic throw out bearing that was leaking fluid onto the clutch after it over extended due to an improperly adjusted clutch pedal stop. The second was a hydraulic throw out bearing that was improperly adjusted at installation and was depressing the pressure plate fingers even when the pedal was not depressed. In both cases it was necessary to remove the transmission and clutch to inspect, diagnose and fix the problem.
Between the paint issue and this..I am almost thinking C8 had been the way to go...lol (hearsay) There hasnt been any leaking underneath but it may be just minor enough to wet the clutch..IDK I hope you are not right.. Even under warranty I have to pay labor, had I known that....sigh
