Old 01-30-2022, 05:11 PM
spdbrake spdbrake is offline
Originally Posted by mavgarb302 View Post
the pedal all feels correct. about an inch push on the pedal and clutch disengages. I assume that is what you mean. I am not new to motorcycle clutches but am new to auto clutches. Basically the same between them except wet vs dry, if this was happening on my bike I'd say worn clutch or weak springs but it is brand new, unless they put a crap weak clutch in it. When it is engaged/engaging it feels good, feels right it isnt until a load is put on it that it starts slipping. The VMAXs old and new are nortorious for this even with new clutches so theres a thing called the double D mod where you stacks clutch springs, unfortunately on this I cannot. But it is exactly the same, just letting loose once engine is over 4k where the 427r really starts pulling.
You should have approx 1/4" freeplay at the clutch pedal before you feel the resistance. Depending on the master cylinder bore dia. After depressing the pedal 2-4" later the clutch should be fully disengaged.
It sounds like your master is mis-rigged and the clutch is 1/2 way depressed at all times, thus the slippage in higher gears.
If yours is a dual disc clutch the 1" pedal travel and full disengage you described still points to a mis-rig.
