  #27 (permalink)
Old 02-01-2022, 01:07 AM
CompClassics's Avatar
CompClassics CompClassics is offline
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
1ntCobra
“So if you order the optional differential, you should definitely make sure that it was installed correctly, because it seems that SAI, Hi-Tech, Hillbank or whoever have installed the optional differential in such a way that it dumps all of the fluid on the street as you drive. Maybe by now they have learned to install the optional differential correctly, but I would not count on it.
The differential thread started in 2017. And yet it continued.
Did they learn to install the differential correctly by 2019? KMS Differential Questions (this link starts at post 1461140) I will give you a hint, the answer is NO.
Did they learn to install the differential correctly by 2020? KMS Differential Questions (this link starts at post 1485154) I will give you a hint, the answer is NO.[/quote]”
Unfortunately, they have not learned how to install the differential properly, nor have they learned the proper use of fasteners (nuts, bolts and washers) in high load / shear applications.
