Old 02-01-2022, 12:50 PM
cycleguy55's Avatar
Originally Posted by MaSnaka View Post
I have seen a slick little bore scope you plug into your I Phone. Sorry I dont have a link. High Def.
I agree with 6TNCRAZY. Pre loaded TO bearing. As the disk wears the fingers move towards the TOB. Slight adjustment may be required.
Good luck,
John
I bought one about 10 years ago. 5 meters long, waterproof, camera end is about 6mm with tiny LEDs for illumination. USB connection that plugs into a laptop or other devicest (with adapters). I haven't tried it with my phone, but will need to check that out one of these days.
It's been quite useful in looking into otherwise inaccessible places - like reading the part number on the failed Corvette A/C relay used in my car as a fan relay. It was mounted on top of the crossbrace above the pedal assembly in my car. I could have removed it to check (which I eventually did), but having the scope was ideal when troubleshooting the problem.
Brian
