Old 02-02-2022, 09:12 AM
cycleguy55's Avatar
Originally Posted by mavgarb302 View Post
Ok, so good news, no leaks. The bad news the HTOB moves with springs, zero gap and if HTOB moves the springs move with it. so I suspect it has constant pressure on clutch. pics will soon be in album
As noted in the McLeod instructions I linked above, McLeod offers a shorter piston if your setup doesn't have the required clearance. The piston is 0.200” shorter than the standard piston. Assuming your HTOB is a McLeod there's thereofore a relatively easy fix, but if so it would seem whoever did the installation and setup didn't take the proper measurements and clearance before bolting it all together. This should be on them to fix. McLeod's Tech Line number is in the linked PDF.
Brian
