Thread: Rear end issues
  #24 (permalink)
Old 02-05-2022, 05:06 PM
169mph 169mph is offline
I think I found the issue. Most everyone told me to check the the front differential bushing bolt. I checked to see if the bolt was there snd if it was make sure it was tight. The bolt was still there and didn’t seem loose. I tried to torque to spec but it would not get tight enough. I took the weight off the differential with a breaker bar and the bolt basically fell out. When I removed the pry bar the differential dropped back to its normal position and the output flanges are no longer rubbing the subframe. What should I do next? Install a new bolt? Replace the bushing and bolt. The bolt doesn’t look like it’s been sheared off to me. I really appreciate everyone’s help to this point. Any advice moving forward would greatly appreciated. Thanks
