Old 02-05-2022, 06:42 PM
1795's Avatar
1795 1795 is offline
Put on wheel to see if I had to file anything for fitment.
Nope, spins rub free no spacer.
Will not use nylok style nuts upon final install.
Using Flexloc style for strength and security.
Jeff,
Looking nice. Good choice not using nylock nuts, it gets pretty hot in there. I use the metal captive nuts.
Take a look at the clearance between the caliper and the wheel spokes. I saw the drilled hole in your spinner. One mine, I cannot use a lock wire as there is not enough clearance between the caliper and the wheel spokes for the wire. You may have enough, but it will be close.
Jim
