Thread: Sidepipes
Old 02-07-2022, 02:41 AM
jaxcobhue jaxcobhue is offline
Banned
Assuming your lines slide the entire way to the spring retainer cuts you have an excessively free of a fit. Get the header pipes extended to take up the slop or you will have an exhaust spill. Check out your edge, you will see where a piece of the level bar has been overlayed on the edge.
Support your sideline subsequent to interfacing with headers and figure out where the openings of the sections should be penetrated. Drill and tap the openings, you will bore through the overlayed level bar and casing.
I made approximately 3/8" spacer to go between the section and casing so the line set level. It is clear once you get into it. lag ja gale lyrics breathless lyrics
