  #29 (permalink)
Old 02-12-2022, 07:16 AM
HTM101 HTM101 is offline
We purchased a Hi-Tech roller (built at that time by current CC member, TJD) in 1994 and still own it. Throughout ownership I have:
a. removed most of the excessive bling I had installed early on, and replaced that with satin black and brushed aluminum.
b. moved the battery from the trunk and replaced it with a pair of batteries placed behind the passenger seat.
c. installed a 42 gallon comp tank.
d. rebuilt and installed a pair of functional Stewart Warner 240A fuel pumps with dual fuel lines from the tank, to the mechanical fuel pump.
e. replaced the 15" steering wheel with a 16" split center Moto Lita wheel.
f. removed the original welded steel rear wheel uprights and replaced those with cast iron uprights/hubs as used in original Cobras.
g. replaced the original cast iron Toploader trans with a new David Kee aluminum case Toploader wide-ratio and big input shaft.
h. replaced the rear wall panel between the seats and trunk, with a new panel that includes the FIA bump-out.
