Old 02-12-2022, 05:35 PM
Soundkillr Soundkillr is offline
Cobra Make, Engine: Backdraft cobra FE big bock
Originally Posted by 169mph View Post
I had the same thing happened last month. Same Bolt sheared. I’m trying unsuccessfully to extract the end of the bolt out without dropping the differential. Tried to use a dremel tool to cut a groove in the end of the bolt so I could back it out with a flat head. Couldn’t cut a groove deep enough. I think lm going to drop the differential and replace the bushings and upgrade the front bolt.
Thanks Mike
Sorry to hear...this is my thought...if you want to try it....im goingnto take a thin copper sleave to protect the threads...then im going to weld a small nut on the back of the broken bolt.....then im going to try and run the bolt forward toward the car. Hopefully this will work...but it will be about 3 weeks before my buddy can help me.
They only drill I could see fitting in that area would be a pneumatic 90 degree drill with a thin chuck. And even then I wouldnt be able to drill straight in for an extractor. If anyone else is dealing or has dealt with a broken bolt...what method worked?
Id rather eat bugs than drop thus differential.
