Old 02-13-2022, 09:31 PM
krausewich krausewich is offline
Cobra Make, Engine: MidStates, 351C, 4spd, 9"
Send a message via AIM to krausewich
As long as you have a little welding experience (an afternoon of practice), you will be fine. A small 140/180 unit will be perfect to move and reweld the thin 3/4 tubework supporting the body as needed. It's all pretty easy.. just add trial fitting and patience. The MK4 FFR body is the only one you would want if you go that route. The belly needs rework to look right, but that's easy enough too. Be picky about the body and chassis you choose. The rest is just supporting structure and aluminum.
"It's not about getting from point A to point B. It is the point"
-J. James
M. Krause
1.508.944.3368
