Old 02-14-2022, 06:13 AM
Lalmeida617 Lalmeida617 is offline
Cobra Make, Engine: Era #634
Wow guys. Ok guys. So to fix the Freeze,Welch, hex clean out plug leaking issue. I must drain the radiator remove plugs with a hex wrench that I will make, and then seal each plug with a high temp rtv? Keep in mind that area gets kinda hot. Is this a common issue on SO?
