Old 02-14-2022, 10:41 AM
patrickt patrickt is offline
Originally Posted by Lalmeida617 View Post
Wow guys. Ok guys. So to fix the Freeze,Welch, hex clean out plug leaking issue. I must drain the radiator remove plugs with a hex wrench that I will make, and then seal each plug with a high temp rtv? Keep in mind that area gets kinda hot. Is this a common issue on SO?
I have never personally touched a side oiler's screw in freeze plugs. But since no else is going to give you any help, I'll refer you to this topic on the FE forum: https://www.fordfe.com/screw-in-free...nt-t95234.html
