Thread: Rear end issues
  #34 (permalink)
Old 02-17-2022, 09:27 PM
169mph 169mph is offline
I decided to drop the different myself and replace the broken front differential bolt. I’m to pull the differential. The only thing left are two rear differential bolts. Took some time and large cheater to break them loose. I know Im only half done but so far it’s been a fairly easy job. The only issue I had breaking the bolts loose on input drive shaft (4 bolts). I had use an open end wrench to remove them. I couldn’t fit a socket or use a cheater pipe. I have lift I know dropping the differential without one would be way more difficult. I’m plan to upgrade the front differential bolt and replace the three bushings. Is there anything else I should do while have differential our? I really appreciate the help. Thanks Mike
