Thread: Rear end issues
Old 02-18-2022, 10:22 PM
SBSerpent's Avatar
SBSerpent SBSerpent is offline
Cobra Make, Engine: BDR build #983, FRM 392
Originally Posted by spdbrake View Post
If you're sticking with the stock forward bolt I'd get the improved BMW OEM bolt. https://www.ecstuning.com/b-genuine-...t/33176760337/
Also if you are considering poly bushings and adjustable lower control arms now would be the time to do it. The Diff has to be slid back 2-3 inches and the axles disconnected to remove the upper and lower inboard control arm bolts.
I just reread the last post. "The crazy thing is when I was turning the bolt I thought I saw the opposite end of the bolt turning too". --- Yes broken bolt can be extracted from the rear of the bolt hole without removing the diff.
If you have a Dremel and a cut-off wheel, cut a slot in the protruding tip of the bolt. Then use a screwdriver to walk it out the back of the bolt bore.
Why does the improved bolt have threads near the head of the bolt whereas the sheared bolt that 169mph experienced has no threads near the head????
