Old 03-05-2022, 08:34 AM
mutt mutt is offline
Does this sound about right for sliding toploader back in order to work on clutch:
- remove collar around shift lever
- from below, remove the two bolts attaching shift lever to shifter mechanism
- remove 4 bolts at rear of driveshaft attaching it to transaxle
- pull drive shaft from toploader and work it out of the way
- remove bolts attaching toploader to bellhousing
- remove two nuts and bolts attaching toploader to frame
- have support ready for toploader
- slide toploader back in tunnel far enough to remove bellhousing
