Old 06-24-2002, 08:18 PM
MoonDog MoonDog is offline
Send a message via ICQ to MoonDog
Default jag rear alignment
Hope you guys can help me..
I took my cobra in last week for a 4 wheel alignment and I was told my rear alignment is out by approx 5mm (1/4 inch). ie, it is crabbing down the road...
He said it would take a full day to align.
He suggested that I do the adjustments myself.
It is a series II Jag rear end.
I noticed that where the lower arm (dog bone) is bolted to the diff housing (shaft) is where the 2 bolts are used to adjust with shims.
Problem looks like I'll have to take out these shafts to access the 2 bolts.
However if the lower arm is off how do you then adjust the angle without the arms on?..
Would appreciate your help in advising me on how to properly align the Jag rear end..ie methods, reference points for measuring etc..
Thanks..
