Old 03-08-2022, 10:20 AM
FredG's Avatar
FredG FredG is offline
Cobra Make, Engine: Backdraft Car #1209 Roush 427R
Default Ground, coil, magnetic pickup.
These are the three most common issues I have seen on the 6AL. As suggested, you need proper grounding. Bad coil, you replaced it but make sure the one you used is compatible with the 6AL. Bad magnetic distributer pickup or broken pickup wire. I experienced the 3rd on my 10 year old car 2 years ago. Pickup wire broke under the insulation. There is an ohm test to check the pickup. Be sure to jiggle the wires when doing it. Good luck.
Fred
