Thread: Paging patrickt
Old 03-13-2022, 06:27 PM
patrickt patrickt is offline
Here's what I would do if you had the distributor out, the plug wires pulled off the cap and now the car won't run. Take the valve cover off the passenger side and watch your #1 valves. Watch the exhaust valve open then close as you rotate the engine from the crank bolt. Now watch the intake valve open. Keep turning on the crank bolt and when the intake valve begins closing, you will be getting closer to TDC so watch your balancer. Stop moving when it's about 30° BTDC. Make sure your plug wires are in the right order on your cap, and going in the right direction, and now point your rotor at the #1 plug. For now, disconnect all the electric leads through your ignition system and "hotwire" it so that the entire ignition system, which is just a couple of wires, be it points/condenser or MSD, is right in front of your eyes. Crank the engine with a remote switch on the solenoid and give it gas by manually moving the carb linkage with your hand. If there is nothing seriously broken in the engine, and you have spark, and you have fuel, your engine will fire up in two seconds.
