Old 03-14-2022, 07:21 PM
HighPlainsDrifter's Avatar
HighPlainsDrifter HighPlainsDrifter is offline
Cobra Make, Engine: F5 Roadster
Default fuses
Try to isolate the shorts by pulling out fuses until it is better, then put one fuse in at a time until you find a bad circuit. Also disconnect the rad fan as it can cause alot of trouble if it is wired anywhere the alternator.
good luck
Perry
F5 cobra Mark 4 roadster, **SOLD** Ruby Wine Red with pearl,
dual 2" roll bars, warmed up 302, Edelbrock AVS carb and heads, E Street aluminum Heads, Comp cam and roller rockers, AOD, 4.10 Eaton Posi, Power Baer/disc brakes, block hugger headers, 2 1/2" under car exhaust, F500 18" black spoke wheels.
