Originally Posted by bobcowan
Since you just need a plug, repair the sensor with some 2 ton epoxy and put it back in.
It’s not repairable but I may be able to cut / grind down the connector so it’s flush with the flange. If that works I’ll fill in the connector with silicone and paint.
If that doesn’t work I’ll order a new sensor.
BTW, I found a speed sensor delete for the sensors mounted to the transmissions.
Thanks, Mike
