Old 04-04-2022, 07:17 AM
Luce Luce is offline
Cobra Make, Engine: Lone Star with IRS, 427W with megasquirt, T56 magnum
If it's running (although slow and rough) I'm assuming you've let go of the starter and the voltage has returned to 12v+ yet it still stumbles and dies.
Unless you want to carry around double batteries like a heavy duty diesel pickup, voltage will sag into the 9's while cranking.
If you've only eyeballed and guessed at the timing rather than having a light on it, my bet is you're a little retarded (not you personally, your timing) You'll do no harm pushing it up 5 degrees sitting at an idle and seeing if it'll run there.
edit- add
The spark happens when the points open, not when they close.
