Old 04-04-2022, 08:35 AM
cycleguy55's Avatar
Check the bushings on the linkage. If you have the nylon bushings, remove them and replace them with the metall ones. The nylon ones will wear and it only takes a little bit of slop to misalign things.
I agree. This sounds like a shifter adjustment issue, and those nylon bushings make that more likely.
To the OP: Hurst shifters are generally pretty easy to adjust, but I know the ability to insert the 1/4" "neutral alignment rod" can be a challenge on Cobras due to the limited space between the transmission and tunnel wall. My car has a Richmond 5 speed street transmission with a Hust shifter and there's no room to insert the pin.
When I had the transmission out last year I took the opportunity to insert the "neutral alignment rod" and get the shift rods carefully adjusted. I then carefully secured the adjustments before removing the shifter to re-install the transmission. It's never shifted better.
Hurst instructions: https://www.shifterdoc.com/Hurst_373...nstuctions.pdf
Brian
