Old 04-04-2022, 08:46 AM
LMH's Avatar
LMH LMH is offline
The tube diameter would be the same as standard Ford tubes using push-on breathers. Not sure off hand what that is but I can measure it on my covers when I’m home. Angles could figured by mocking the tubes up in cardboard on covers mounted on an engine. Same with the braces. The GT350 style breather setup you’re looking at had a baffle inside the cover.
Alba gu brąth
