Thread: Bolt Pitch
Old 04-07-2022, 10:39 AM
spdbrake spdbrake is offline
I found it easier to have the diff sitting vertical on the jack at the lowest part of the aft cover. Jack it slowly and tilt the nose down as it comes up. You want to make sure the jack has a bearing surface that will contact the bottom of the diff once it goes horizontal. Get one aft cover bolt started and then you should be home free.
