Thread: I need help
Old 04-11-2022, 01:28 PM
Unique427 Unique427 is offline
The easy answer is to separate your Cobra key
from all the other items. What wears a keyed
ignition out prematurely causing a fault is dangling
all that from it.
But, if that's not for you, could plug the existing
ignition hole with a "Push To Start" button, then
relocate the ignition key hole where desired.
You would then use the key for power on and
the push botton to momentary crank the starter.
Example:
https://www.amazon.com/Jtron-Ignitio.../dp/B00RVBGHZS
