Old 05-15-2022, 07:01 PM
mrmustang's Avatar
mrmustang mrmustang is offline
Gold Star Contributor
Originally Posted by xb-60 View Post
Bill, what about on the side of your glovebox? Sufficiently out of site, and you could have a short extention cable to make access easier.
Glen
I got home earlier this evening and took some pictures of the under dash areas from one side to the other. One of the areas I'm looking at is indeed the side the the glovebox with a weather tight enclosure bolted to it. Found a small dual plug unit that I should have in hand tomorrow night to see if that may or may not work.
I think now I'm more concerned where to tap in for power and ground purposes. Clearly "key on" only will be needed, it has been suggested a lug off the ignition switch, which one that is, I am uncertain at this time. For ground, I should be able to use a self tapping screw in to any of the exposed metal framework under the dash, provided it is not close to anything else the screw might come in contact with.
Bill S.
