Old 05-15-2022, 07:26 PM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is offline
Consider that in every vehicle I've ever owned the power port is on a dedicated circuit since they are usually rated to 10 or 15 amps. Check to see if you have an open fuse position and connect it there. I realize that a USB plug in adapter uses less but nonetheless you need to be conscious of current draw wherever you tap.
Tony
CSX4005LA
