Old 05-15-2022, 07:28 PM
xb-60's Avatar
xb-60 xb-60 is offline
....I think now I'm more concerned where to tap in for power and ground purposes. Clearly "key on" only will be needed, it has been suggested a lug off the ignition switch, which one that is, I am uncertain at this time. For ground, I should be able to use a self tapping screw in to any of the exposed metal framework under the dash, provided it is not close to anything else the screw might come in contact with...
Do you have easy access to the fuse box/block on an SPF MkII?
I'm assuming yes, so there might be a spare tab that's power/ignition on that you could use, otherwise piggy-back onto the wipers/washers tab or instrument lights tab in the fuse block?
Then, as you described for the earth connection.
Glen
