Old 05-23-2022, 11:36 AM
CHANMADD's Avatar
CHANMADD CHANMADD is offline
I have an oil pressure cutout switch on my car.. The engine will crank until the oil pressure comes up and then the switch will set the fuel pump relay. The switch should be located at the oil pressure takeoff point on the block. So when there is no fuel pressure it will not start....until you've cranked the oil pressure up. Also if you run out of oil the motor will stop.. If you crash and stall the fuel pump will stop as soon as the oil pressure drops.
