Old 05-24-2022, 12:04 AM
FlyingGumby's Avatar
FlyingGumby FlyingGumby is offline
Cobra Make, Engine: BDR #870 Salsa Red w/White stripes Roushcharged 4.6L 3V
The smallest upper pad is 5mm thick and comes thicker in 5mm increments. Think the bottom is one size. I thought about using different size upper pads on the bottom but concerned the spring would slip off the perch. The bottom pad looks secure.
I suppose you could also craft something out of different material to get the thickness you want. The original gasket like material lasted 10 years but probably failed sooner.
