Thread: Battery Ground
Old 05-24-2022, 05:33 AM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
The ground cable chassis mount is near the battery and is attached to the frame with a bolt located between the battery and the tail light. If you press on the small section of the carpeting in the trunk between them, you will feel the bolt head. Actual connection is under the car.
If you (or anyone else) sends me an email I’ll send a photo of some nice keepers for the battery you can source locally using the 2 existing rods on the car. Inexpensive and an easy fix assuming you have the proper size battery installed.
My contact info is below.
Blas
P.S. I recommend you add your Superformance chassis number to your personal data displayed or in every posted question you make. I have 6 different versions of the Wiring Diagrams available, all dependent on a chassis number to get the correct version.
SPFWiringDiagrams@Comcast.net
