Old 05-24-2022, 08:19 PM
SBSerpent's Avatar
SBSerpent SBSerpent is offline
Cobra Make, Engine: BDR build #983, FRM 392
Originally Posted by FlyingGumby View Post
I recall trying to remove the springs last year and gave up because removing shocks and sway bar mount was not enough. The upper treaded collar keeps the spring from coming out easily. BMWs don't have this. Had not considered just loosening bolts per spdbrake. Worst case would be unbolting things until you get enough clearance which is not hard but time consuming.
But you were able to do it judging from the photo of the rear spring and the damaged pads that you show a few posts back....
