Old 05-25-2022, 07:04 AM
msinc msinc is offline
Cobra Make, Engine: Superformance aluminum 427FE
i doubt omitting the gasket creates any issues since as you said it’s very thin. I put two gaskets on mine and it was fine. There should be lube getting through the Rear bearing unless somehow a sealed bearing was installed. I would suspect something amiss with the speedometer gear adaptor.
"speedometer gear adapter"??? Can you clarify what you are calling an adapter please sir??? I am not familiar with what that is. I will definitely inspect that bearing...it would be just like my luck to have had some idiot install a shielded or sealed bearing in place of the correct open one!!!! Thanks for the info!!!! M
