Old 05-25-2022, 03:35 PM
CJ428CJ's Avatar
CJ428CJ CJ428CJ is offline
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
I've been using the Optima 35R in my ERA with the battery under the right front fender. It does have the end tabs to allow the ERA provided battery hold down to be used (although I did have to put a spacer under the battery). I like it so much better than the old lead acid battery I used to use. The lead acid battery would "sweat" acid which would drip down and stain my stainless pipes. I've had the Optima for 3-4 years with no problems (and I use a 120A 1-wire alternator).
Chris
