  #26 (permalink)
Old 05-28-2022, 07:13 PM
Mike_Gr Mike_Gr is offline
Originally Posted by FlyingGumby View Post
Subframe and diff came out easily.
Going the monoball route for RTAB. What poly diff carrier bushings are recommended these days. Choices seem limited with 14mm front carrier bolt. Or, just drill the a 12mm bushing sleeve to accommodate 14mm bolt?
Saw on another thread that you did a major upgrade after using a DSB. I don't want to go that far but do you recommend a DSB? Is your used one still available.
Thanks.
I would absolutely use a differential support bracket as piece of mind that the front of the diff wont twist under torque load. (My bracket is pending locally). I cant recommend any specific poly diff bushings. I used solid diff bushings and motor mounts.
For camber arms, I used SPC and have had good luck with them.
