Old 06-05-2022, 04:58 PM
Mike_Gr Mike_Gr is offline
Originally Posted by Morris View Post
When you get in the car ...your body weight will only be on the LF, LR, & RR....
The car was corner weighted with driver in it after the one I showed above. Only showed that as they asked total weight with top. Slightly higher weight on left side of car. Cross weights are really close. I am thinking of getting a set of scales so I can play around with this a bit after I dial in the suspension. That in itself is completely adjustable now so could take a bit of fine tuning.
