Old 06-06-2022, 05:25 PM
Morris Morris is offline
Cobra Make, Engine: Kirkham #259
Originally Posted by Mike_Gr View Post
The car was corner weighted with driver in it after the one I showed above. Only showed that as they asked total weight with top. Slightly higher weight on left side of car. Cross weights are really close. I am thinking of getting a set of scales so I can play around with this a bit after I dial in the suspension. That in itself is completely adjustable now so could take a bit of fine tuning.
Your tire temps when you come in off track are very important to balance the chassis.....also the tire pressure is equally as important....
So the question becomes do change a tire pressure....or a corner height...or a sway bar setting ...or a shock setting...multiple choice.....
Morris
