Old 06-10-2022, 01:04 PM
C5GTO's Avatar
C5GTO C5GTO is offline
Originally Posted by sunman View Post
The emissions connection on the fuel tank sender is connected to the charcoal canister then to the purge solenoid then to throttle body vacuum port. To vent the tank. Check the line, is purge solenoid working?
You are pumping gas to the cap with return line also, that’s dangerous. Nobody does that.
Increase in elevation possibly makes problem worse.
This Cobra has no emissions equipment installed. No charcoal canister, no purge solenoid, etc.
Thanks,
Joel Heinke (early 90's CRL Cobra)
