  #30 (permalink)
Old 06-12-2022, 10:04 AM
sunman's Avatar
sunman sunman is offline
Great idea simple with a little line it will lay on tank floor. You have a code 85, canister problem. Solenoid has power to it and ECU grounds it to open at cruise. Pin 31 on ECU gray and yellow wire. Easy to add a canister, solenoid and vacuum fitting. Add a tee next to corner vent on tank for vacuum connection. Ford wouldn’t have it if it wasn’t needed.
Chaney Shores Studio
