Old 06-25-2002, 09:00 PM
cobrashoch cobrashoch is offline
Cobra Make, Engine: Home built, supercharged 544cu/in automatic
Bowtie - Your combo should produce the promised mid 11's easy. Don't forget you will weigh in at about 2500 lbs plus or minnus. What you will not like is your 60 ft. times. Most guys that run Cobras in the mid 11's sixty ft. at around 1.6 or 1.7. That's the nature of the beast! A mid 11 second blast with a drag car will usially have 1.3's sixty foot times so it shows you that most Cobras have that big end charge we all like. It's also been my experience that because of the 60 ft. times thing most Cobras will run about the same regardless of big block or small block. (sorry guys) There are a few guys out there that run them better but they are not the rule. Yes, you may see 10's if you go after that but I'm betting you will be having to much fun with your car to be doing such things. Welcome aboard to the madness train.
cobrashoch
Ron Shockley
