Old 06-20-2022, 07:41 AM
C5GTO's Avatar
C5GTO C5GTO is offline
Originally Posted by Hapnyny View Post
Thanks everyone!
So the 92 CR has a fox body rear ended? I know it’s an 8.8, so when I start rebuilding should I be purchasing 90 Fox Body rear end parts?
Thanks again for your insight!
I have a 9 inch in my CR. The suspension is Fox Body but the rear axle doesn't need to be. I bought the 9 inch already shortened, with the proper 4 bar mounts welded on, a posi diff and converted to disc brakes from Currie Enterprises back when I put my CR together. There are probably better sources for such a package these days but you should be able to source a pre-made unit.
If you are thinking big HP/torque, the 9 inch is a proven answer. I did also add on a Panhard bar to the setup and the car handles like it's on rails
Thanks,
Joel Heinke (early 90's CRL Cobra)
