Thread: Brake lights
Old 06-25-2022, 07:57 AM
Unique427 Unique427 is offline
Originally Posted by w-lewis View Post
I believe I found it. A fitting screwed into the brass brake line junction block.
If it looks like this you found it.
https://www.speedwaymotors.com/Brake...SABEgJJhvD_BwE
They do go bad, as in not working, intermittent or you have to
pump the brakes up to make it work. Don't rule out a bad wire.
Sometimes one of the two wires simply pop off the bayonet plug too.
You may or may not have to bleed the brakes after install.
