Old 07-01-2022, 10:10 AM
RonKahn RonKahn is offline
Cobra Make, Engine: Classic Roadsters, 347 stroker
Originally Posted by spdbrake View Post
Trans ID and dimensions along with swapping the input shaft to make yours work is here: https://www.jalopyjournal.com/forum/...rticle.171291/
But back your contact at Tremec. They weren't able to give you the info? They've been pretty squared away on the few calls I've have with them.
They are only able to tell me if the shaft is longer, which I have asked and not had a response back yet. I am assuming it is, and according to the article, it is .067" longer. So my question to everyone is if the bellhousing from a 94-95 is also .067" longer to accommodate the longer input shaft.
I really don't want to swap out the input shaft if I don't need to. I would then have to also swap out the bellhousing and possibly even the starter.
