Old 07-08-2022, 04:47 PM
S1965C S1965C is offline
Originally Posted by zzmac View Post
I understand replacing the relay sensor by the rad is a pain in the ass so I want to start by at least fixing the manual switch for now.
It's not so bad if you take a Dremel with a cutting bit and remove a little of the inner 'glass fender near the sensor. You don't have to drop the radiator. It also helps to have a deep socket that fits the size of the sensor, too.
But I agree with the others to check your grounds first. Then the manual switch. The two-way Lucas switches are cheap and will fail easily if worked too much.
