Old 07-10-2022, 12:51 PM
NROTOXIN NROTOXIN is offline
Cobra Make, Engine: SPF832, 466cid
The jumper to the fans shows that the fans do work, which is good but does not test the rest of the circuitry consisting of the relay, two 20A fuses and the thermal switch. The relay is behind the dash, the fuses are on the drivers fender well. When idling, the only indication that my fans come on is my amp gauge goes just negative of zero. The override switch simply shorts the thermal switch and relay coil (86) to ground that then energizes the relay coil. If you don't have a ground connected at the thermal switch or brn/blue at that same switch, nothing will work. What's equally important is your source voltage to the relay (30), connectors at the relay (87) that come from the two GOOD 20A fuses.
