Old 07-11-2022, 07:50 AM
spdbrake spdbrake is offline
Originally Posted by genolan View Post
Besides replacing the clutch any other methods to reduce pedal pressure? I just put in a new wilwood master and slave .75 bore
Gary, The Wilwood slave (pull type) is a 7/8" unit.
https://www.wilwood.com/MasterCylind...temno=260-1333
Can you you clarify what you installed?
If you did install a BDR supplied slave (aka Mazda B2200), this unit should work. Dimensions are listed to compare to your footprint.
https://www.speedwaymotors.com/Speed...AaAjChEALw_wcB
