Thread: Coyote Owners
Old 07-12-2022, 05:19 PM
eschaider's Avatar
Originally Posted by SBSerpent View Post
"When your engine is running you will need one more quart of oil to wet the inside of the engine. In addition to that you will have somewhere between a ½ quart and ¾ quart of oil in suspension around the rotating assembly."
I recently installed an Aviaid pan that has a 6 quart capacity. Prior to installation I filled it with 6 quarts of water to confirm that the fluid is just at the baffle. Am I to understand that an additional quart of oil is to be added to the stated capacity from the manufacturer to account for oil that is suspended in the engine when running, bringing the total capacity to 7 quarts?
You are reading the tea leaves correctly SBSerpent. Between what is required to wet the engine internals and the oil in transit back to the pan you approximate a quart. A big block with more internal real estate will take a bit more to do the same job. The "extra" quart you add to the engine just brings the oil level in the sump back to where it was before it lost the oil to wet the engine internals.
