Old 07-13-2022, 07:53 AM
Dominik's Avatar
Dominik Dominik is offline
Speak to your engine builder about maximum piston to deck height (quench area).
If it becomes too big, i.e. by using a thicker gasket, you may experience exactly what you try to avoid: uncontrolled pre-ignition/detonation.
Also, your cam may be perfecly matched to your CR and you lose quite some torque and power by dropping CR. This is a lesser problem.
I feel that recurving the timing is in order once done.
If I don't respond anymore, that's because I can't log in
